TACACS is a network security application that provides additional network security by providing a centralized authentication, authorization, and accounting platform. TACACS implementation requires configuration of the TACACS authentication server and database.
Use the (config) instance to configure AAA-TACACS policy commands. To navigate to the config-aaa-tacacs-policy instance, use the following commands:
<DEVICE>(config)#aaa-tacacs-policy <POLICY-NAME>
nx9500-6C8809(config)#aaa-tacacs-policy test nx9500-6C8809(config-aaa-tacacs-policy-test)#? AAA TACACS Policy Mode commands: accounting Configure accounting parameters authentication Configure authentication parameters authorization Configure authorization parameters no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-aaa-tacacs-policy-test)#
